6504 Backplane capacity using SUP 720 3B
Does the 6504 have a full capacity of 256Gig (i.e, 32G * 8)
Hall of Fame Super Bronze
Re: 6504 Backplane capacity using SUP 720 3B
Sup 720 has the following feature:
Integrated 720-Gbps Switch Fabric
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/supe_gd/02superv.htm
Hall of Fame Super Blue
As Edison has said the Supervisor 720 supports a 720Gbps switch fabric ie each slot aupports 2 x 20Gbps connectors to the switch fabric. So for example on a 6509 switch
2 x 20Gbps = 40Gbps x 9 = 360.
Cisco then multiple this figure by 2 for full duplex transmission to get 720Gbps.
So AFAIK with a 6504-E chassis you would get
2 x 20Gbps = 40Gbps * 4 = 160 Gbps x 2
= 320Gbps capacity.
Jon
443
