6504 VSS
 Can VSS be configured and achieved with single SUP in each switch ?
Silver
Sure - just make sure that
Sure - just make sure that SUP supports VSS.
HTH,
Dragan
HTH, Dragan
Hi,yes it supports , Virtual
yes it supports , Virtual Switching Supervisor 720-10GE (VS-S720-10GE-3C and VS-S720-10GE-3CXL)
Below  link FAQ's  FYI
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-virtual-switching-system-1440/prod_qas0900aecd806ed74b.html
Naveen
**rate if it is helpful***
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As the other posters have noted, yes it can, if fact I believe historically multiple sups, in same chassis, VSS came in a later IOS version.
As the other posters have also noted, you need a VSS capable sup, either the VS-S720 or the sup2T.  You also need an IOS vesion that supports VSS.  Lastly, VSS imposes some additional restrictions on what line cards are also supported.
28
