6504e, need to make Etherchannel down when any member is down
Hi all,
I have 6504e with 2 Etherchannels (2x1Gbps links in each), active and standby, BGP over each towards ISP.
Need to make etherchannel up ONLY when both members are up, to make etherchannel always have a capacity of 2Gbps.
Any idea?
1 ACCEPTED SOLUTION
This is supported for LACP Etherchannels.
This feature is called Minimum-Links
It allows you to configure the minimum number of member ports that must be in the link-up state and bundled in the EtherChannel for the port channel interface to transition to the link-up state.
int po1
port-channel min-links x (X is you value)
So in your instance it should be
int po1
port-channel min-links 2
That way if 1 fails, you do not have a minimum of 2, and the port channel will go down
This seems to be only available with LACP
int po1
int po1
Thanks a lot!
151
