6506 sup1a problem
6506 sup1a image corrupted, downloaded image via console after downloading, sup1a uncompressed the image but failed with this error:
Uncompressing file: ######################
*** TLB (Load/Fetch) Exception ***
Access address = 0xfffffdc0
PC = 0x80010604, Cause = 0x8, Status Reg = 0x3041c003
Any experience on this?
Re: 6506 sup1a problem
Hi Friend,
I beliee you are in rommon prompt and you are trying xmodem? If yes can you specify what rate you are trying with xmodem and also if you have catos or ios on your sup 1a.
DO you have pcmcia card also on which image is loaded? This problem could also be because of bad image so you can try downloading image again from cco and try xmodem.
Ankur
Right. the image was corrupted so I used xmodem to download the new image(tried both 9600 and 38400bits). Image seems downloaded successfully via xmodem, but sup was not able to load it.
I don't have pcmcia card.
tried different catOS version, but all came to same error. weird.
202
