6509 and fabric enabled modules
Hi everybody.
We have a 6509 switch witch Sup2, and NO fabric modules (SFM).
We want to insall a module with many GBIC, so I've thought that WS-X6516A-GBIC is a good choice.... but:
- this module work without SFM?
Obviously, if it work, it doesn't reach fabric performarces, but this isn't a problem.
Thank
Daniele
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: 6509 and fabric enabled modules
Hi Daniele
Yes this module will work without an Switch fabric module. It will use the 32Gb shared bus connection if there is no SFM module in your switch.
Hi Daniele
thanks everybody for your helpful informations
Daniele
Hi Daniel,
Yes this module will work without SFM also.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet0900aecd801459a7.html
Ankur
135
