6509 and HSRP
I am using two Cisco 6509 chasis acting as access/distribution switches. So I dual homed hosts connected to these switches. One NIC to each switch. Can I use HSRP between the two switches to provide fault tolerance when NIC1 is connected to one switch and NIC2 is connectyed to another?
Help well rated.
Gavin
1 REPLY
Hall of Fame Super Blue
Re: 6509 and HSRP
Hi Gavin
Yes, you can use HSRP for this, indeed this is exactly what HSRP was designed for.
Do you have a layer 2 trunk between your 2 6500 chassis ?
If so it is fairly straighforward eg.
6509_1
interface Vlan50
description xxxx
ip address 10.181.120.2 255.255.255.12
no ip redirects
standby 50 ip 10.181.120.1
standby 50 timers 1 5
standby 50 preempt
standby 50 authentication "xxx"
6509_2
interface Vlan50
description xxxx
ip address 10.181.120.3 255.255.255.128
standby 50 priority 50
Then set the default gateway on your host to point to 10.181.120.1
Jon
268
