6509 blade shut down with errors
We have a 6509 that had a blade down this morning with the following errors shown below.
Every port on the 48 port blade was down. I first di a shut/no shut on each interface.
This brought up the interfaces but they would not pass traffic.
I pulled the blade and plugged it back in, not sure if this was the correct course of action, but the ports passed traffic after that.
My questions are:
1. Is there any way to do a shut/no shut on multiple interfaces at once?
2. Could this have been a STP issue and what would have been the correct way to resolve it?
The whole blade, possible hardware?
I did not see any errors pointing hardware in the logs, only these two errors on each port:
May 18 07:21:35.410: %PM-SP-4-ERR_DISABLE: packet-buffer error detected on Fa5/14
, putting Fa5/14 in err-disable state
May 18 07:21:44.869: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 5/14 i
s powered up but its link is not up in 5 seconds. Therefore, power is withdrawn
from the port.
Re: 6509 blade shut down with errors
With regards to disabling and enabling multiple interfaces in one go you can use the interface range command.
config#interface range f5/1 - 24
config-if#shut
config-if#no shut
I am not sure about the issue itself though.
We're seeing the same issues on WS-X6148-GE blades. Our support provider is stumped, though we've found a quick fix is to reset the module and it runs okay after that. Did you ever find out what caused this?
380
