Community Member
6509 chasis
I am getting this error %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host.Please suggest the solution As soon as possible because it hamper my network
Highlighted
Purple
Re: 6509 chasis
Someone is trying to use snmp on your 6500 , if it doesn't tell you in the logs what address then you might have to use a sniffer . If it tells you then track down the address and ask the the user why his device is attempting an snmp query on that device.
Community Member
Re: 6509 chasis
Hi Thanks for the reply the host Ip address showing by the logs is one of my application server. kindly suggest the solution that how can i eradicate this issue
Community Member
Re: 6509 chasis
look in the server whether i genuinly uses the SNMP, if not stop any SNMP service on that server
--srini
192
