02-10-2014 02:19 PM - edited 03-07-2019 06:07 PM
I'm configuring a 6509 core switch that has 4 blades and each blade has 48 ports by default the ports are shutdown. I know I can do a port range with a no shutdown command to brings all ports up for each blade. However is there only one command that can make all ports active on each blade or a module command that can bring all ports for each 48 port blade?
02-10-2014 02:29 PM
Horacio
From memory the int range command can be used to specify ports on different linecards so you could try one command that includes the range for all ports on all linecards. Cant say for sure it will work but i seem to remember doing something like this before.
Jon
02-10-2014 02:35 PM
Do u remember the format of the command?
02-10-2014 02:38 PM
conf t
interface range G1/1 - 48 , G2/1 - 48 , G3/1 - 48
no shutdown
end
