6509 core switch
I'm configuring a 6509 core switch that has 4 blades and each blade has 48 ports by default the ports are shutdown.  I know I can do a port range with a no shutdown command to brings all ports up for each blade. However is there only one command that can make all ports active on each blade or a module command that can bring all ports for each 48 port blade?
Hall of Fame Super Blue
6509 core switch
Horacio
From memory the int range command can be used to specify ports on different linecards so you could try one command that includes the range for all ports on all linecards. Cant say for sure it will work but i seem to remember doing something like this before.
Jon
6509 core switch
Do u remember the format of the command?
Hall of Fame Super Gold
6509 core switch
conf t
interface range G1/1 - 48 , G2/1 - 48 , G3/1  - 48
no shutdown
end
75
