6509 drops legitimate traffic - free up buffer
I have a 6509 switch that shows high counters on ifOutDiscards. Cisco Interpretent tool says that reason for discarding such a packet can be to free up buffer
space.
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65408K 43673K 21735K 16384K 9913K 6471K 512K 285K 227K
This shows that i still have unused DRAM
show counter 1/1
64 bit counters
0 rxHCTotalPkts = 6861779
1 txHCTotalPkts = 8077616
2 rxHCUnicastPkts = 6279025
3 txHCUnicastPkts = 7818555
4 rxHCMulticastPkts = 516192
5 txHCMulticastPkts = 191800
6 rxHCBroadcastPkts = 66551
7 txHCBroadcastPkts = 67261
16 txHCTrunkFrames = 8056140
17 rxHCTrunkFrames = 6785673
18 rxHCDropEvents = 0
32 bit counters
0 rxCRCAlignErrors = 0
1 rxUndersizedPkts = 0
2 rxOversizedPkts = 0
3 rxFragmentPkts = 0
4 rxJabbers = 0
5 txCollisions = 0
6 ifInErrors = 0
7 ifOutErrors = 0
8 ifInDiscards = 0
9 ifInUnknownProtos = 0
10 ifOutDiscards = 49145
11 txDelayExceededDiscards = 0
12 txCRC = 0
13 linkChange = 0
14 wrongEncapFrames = 0
0 dot3StatsAlignmentErrors = 0
1 dot3StatsFCSErrors = 0
2 dot3StatsSingleColFrames = 0
3 dot3StatsMultiColFrames = 0
4 dot3StatsSQETestErrors = 0
5 dot3StatsDeferredTransmisions = 0
6 dot3StatsLateCollisions = 0
7 dot3StatsExcessiveCollisions = 0
8 dot3StatsInternalMacTransmitErrors = 0
9 dot3StatsCarrierSenseErrors = 0
10 dot3StatsFrameTooLongs = 0
11 dot3StatsInternalMacReceiveErrors = 0
0 txPause = 0
1 rxPause = 0
0 rxTotalDrops = 11
1 rxFIFOFull = 0
2 rxBadCode = 0
Last-Time-Cleared
Thu Oct 11 2007, 07:33:47 (yesterday)
CPU is at 4-5%
ifOutDiscards increas, 3-4 per second.
Another error msg I got is:
%SYS-4-SUPERVISOR_ERR:Forwarding engine IP checksum error counter = 3529994
Indicates that the
switch forwarding engine has received an IP packet that is less than the minimum
length allowed for IP-packets
show counters supervisor
Forwarding Engine Error Stats Counters
IP len against Physical length err = 2
IP min. length check error = 0
IP pkts with cksum error = 49618
IPX len against Physical length err = 0
IPX min. length check error = 0
I dont know if these two errors are related. The first error says its problem is with memory and the second says its not a problem on the switch itself only on incoming traffic. Hope someone has a clue.
1 REPLY
Bronze
Re: 6509 drops legitimate traffic - free up buffer
You could change the flowcontrol settings back to their defaults: off for Rx and disired for Tx. At these settings, the switch will ignore any pause frames sent by the server and just continue to send traffic. If the server is capable of "digesting" the frames at the rate they are coming out of the switch then this will solve the problem. If the server is not able to handle the traffic, then all
this will do is move the drops from the switch to the server.
524
