6509-E VSS 10gb port count
Hey All,
Has someone created two 6509s as VSS with just one 10gb connection?
I know it is recommened to use both the 10gb connections on the sup-720 from below configuration guide
Information about VSL Topology
A VSS contains two chassis that communicate using the VSL, which is a  special port group. Configure both of the 10-Gigabit Ethernet ports on  the supervisor engines as VSL ports.
But will the VSS come up if I use just the one?
Many Thanks,
1 ACCEPTED SOLUTION
Hi Alan,
This still be working. Though it is a subject for more often occurrencies of dual-active scenario and consequent automatic actions to recover from it. As single linke issue will cause the VSL link failure while with dual VSL link VSL will still be up.
Nik
Hi Alan,
Nik
Thanks for the confirmation Nikolay.
383
