6509 Fan is fail but my switch is still running explain me please
Hi all,
in my 6509 switch  while i checked  is showing some thing like please explain me about this
RDCCI65F0#sh environment
environmental alarms:
  no alarms
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6509-E-FAN
  fan-tray 1 mode: restricted-power
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 22C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 24C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 28C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC high
  power-supply 1 power-output: high
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC low
  power-supply 2 power-output: low
  power-supply 2 power-output-fail: OK
module 1:
  module 1 power-output-fail: OK
  module 1 outlet temperature: 26C
  module 1 inlet temperature: 23C
  module 1 device-1 temperature: 31C
  module 1 device-2 temperature: 27C
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 34C
  module 2 inlet temperature: 21C
  module 2 device-1 temperature: 20C
  module 2 device-2 temperature: 27C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 24C
  module 5 inlet temperature: 20C
  module 5 device-1 temperature: 28C
  module 5 device-2 temperature: 28C
  module 5 asic-1 (SSO-1) temp: 20C
  module 5 asic-2 (SSO-2) temp: 20C
  module 5 asic-3 (SSO-3) temp: 20C
  module 5 asic-4 (SSO-4) temp: 20C
  module 5 asic-5 (SSA-1) temp: 19C
  module 5 asic-6 (HYPERION-1) temp: 20C
  module 5 RP outlet temperature: 23C
  module 5 RP inlet temperature: 23C
  module 5 EARL outlet temperature: 29C
  module 5 EARL inlet temperature: 18C
module 6:
  module 6 power-output-fail: OK
  module 6 outlet temperature: 23C
  module 6 inlet temperature: 20C
  module 6 device-1 temperature: 27C
  module 6 device-2 temperature: 27C
  module 6 asic-1 (SSO-1) temp: 20C
  module 6 asic-2 (SSO-2) temp: 20C
  module 6 asic-3 (SSO-3) temp: 20C
  module 6 asic-4 (SSO-4) temp: 20C
  module 6 asic-5 (SSA-1) temp: 20C
  module 6 asic-6 (HYPERION-1) temp: 20C
  module 6 RP outlet temperature: 21C
  module 6 RP inlet temperature: 22C
  module 6 EARL outlet temperature: 27C
  module 6 EARL inlet temperature: 20C
chassis connector rating: 2016.00 Watts (48.00 Amps @ 42V)
module 1
  module 1 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 1 power consumption: 125.16 Watts ( 2.98 Amps @ 42V)
module 2
  module 2 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 2 power consumption: 125.16 Watts ( 2.98 Amps @ 42V)
module 5
  module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 5 power consumption: 282.24 Watts ( 6.72 Amps @ 42V)
module 6
  module 6 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 6 power consumption: 282.24 Watts ( 6.72 Amps @ 42V)
chassis per slot cooling capacity: 70 cfm
  module 1 cooling requirement: 30 cfm
  module 2 cooling requirement: 70 cfm
  module 5 cooling requirement: 35 cfm
  module 6 cooling requirement: 35 cfm
RDCCI65F0#
Hi Aman,
Can you please advise why you think you have a problem with FAN? Did you get any logs?
From this output:
fan-tray 1:
We see that fan is in restricted mode which is default for 6509-E chassis. Also Fan as per the logs below provide enough cooling for modules:
thus all modules running fine.
Nik
Bronze
Hi Aman, that is normal behaviour for the E chassis.
The fan assembly has 2 modes of operation, restricted-power (normal) and high-power (when you have linecards that require extra cooling).
It would be worth checking your power presentation though as PSU 2 is showing low input power.
power-supply 2:
  power-supply 2 power-input: AC low    <-------
Hope this helps.
Please rate useful posts.
348
