6509 memory issues
For 2 days, i've been encountering memory issues on my core router (6509). Here are the most usefull commands, can i tune something or must i upgrade the memory ?
ROUTER#sh memory allocating-process totals
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 4463C520 396081888 325796272 70285616 69317584 70122888
I/O 8000000 67108864 10418792 56690072 53669600 56614072
Allocator PC Summary for: Processor
PC Total Count Name
0x40D479EC 131971280 1072044 SNMP Traps
0x40D476C4 105589248 1076687 Cat6k SNMP Trap handler
0x4048F804 24822064 4 Init
0x40D896C4 10514000 1 CEF Reloader
0x41481E40 7172064 8301 *Packet Header*
0x41AF0820 2680704 334 Interrupt Stack
0x41490610 2388672 319 *Hardware IDB*
0x416172D0 2089016 1 CWAN LTL PW info
0x417C9004 1842984 179 HWIF-QOS-SB
0x410DFC94 1541144 12829 draco-oir-process:slot 7
0x41943640 1239384 9 PM port_data
0x40516D0C 1184712 255 FIB: event log data
0x40E8F74C 1009104 69 List Elements
0x4064F77C 918288 14 IPC Message He
0x410BEA0C 875784 26 FIB 1 path chu
0x40D7AAB4 875120 64 Init
0x4149062C 732424 319 *Software IDB*
0x41569DD8 710304 140 Init
0x4163C478 655416 1 Init
sh ver
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Wed 08-Feb-06 13:31 by kellmill
Image text-base: 0x40021040, data-base: 0x42B48000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXE5, RELEASE SOFTWARE (fc1)
C_QUAI_RGA-6509_1 uptime is 1 year, 6 weeks, 23 hours, 45 minutes
Time since C_QUAI_RGA-6509_1 switched to active is 1 year, 6 weeks, 23 hours, 47 minutes
System returned to ROM by reload (SP by reload)
System restarted at 17:04:42 WEST Sun Apr 1 2007
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-18.SXE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
ROUTER (R7000) processor (revision 2.0) with 458720K/65536K bytes of memory.
Processor board ID SCA042801ZP
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
34 Virtual Ethernet/IEEE 802.3 interfaces
24 FastEthernet/IEEE 802.3 interfaces
138 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Re: 6509 memory issues
Your 6509 has 64M and uses about 10M with 54M free. This seems not to be critical or abnormal.
Which kind of issues are you encountering? Do you have any log messages or other indications you base your statement on and can you post them?
Regards, Martin
This line seems critical,
Thx
Your first output (show mem stat) shows that the router is using about 326MB of processor memory. That is pretty high. The second output (show mem alloc totals) shows that 2 functions are responsible for over 200MB of the used memory. That is a big red flag and suggests that there is a memory leak on this box (always a software problem). These 2 functions are both used by SNMP.
I think you are hitting CSCsg77142. This won't get fixed in the 12.2(18)SXE throttle, so you'll have to move to SXF. 12.2(18)SXF14 is the most reasonable upgrade path.
You'll have to reload or do a switchover to a standby supervisor to clear the problem in the meantime.
297
