6509 memory issues
For 2 days, i've been encountering memory issues on my core router (6509). Here are the most usefull commands, can i tune something or must i upgrade the memory ?
ROUTER#sh memory allocating-process totals
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 4463C520 396081888 325796272 70285616 69317584 70122888
I/O 8000000 67108864 10418792 56690072 53669600 56614072
Allocator PC Summary for: Processor
PC Total Count Name
0x40D479EC 131971280 1072044 SNMP Traps
0x40D476C4 105589248 1076687 Cat6k SNMP Trap handler
0x4048F804 24822064 4 Init
0x40D896C4 10514000 1 CEF Reloader
0x41481E40 7172064 8301 *Packet Header*
0x41AF0820 2680704 334 Interrupt Stack
0x41490610 2388672 319 *Hardware IDB*
0x416172D0 2089016 1 CWAN LTL PW info
0x417C9004 1842984 179 HWIF-QOS-SB
0x410DFC94 1541144 12829 draco-oir-process:slot 7
0x41943640 1239384 9 PM port_data
0x40516D0C 1184712 255 FIB: event log data
0x40E8F74C 1009104 69 List Elements
0x4064F77C 918288 14 IPC Message He
0x410BEA0C 875784 26 FIB 1 path chu
0x40D7AAB4 875120 64 Init
0x4149062C 732424 319 *Software IDB*
0x41569DD8 710304 140 Init
0x4163C478 655416 1 Init
sh ver
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Wed 08-Feb-06 13:31 by kellmill
Image text-base: 0x40021040, data-base: 0x42B48000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXE5, RELEASE SOFTWARE (fc1)
C_QUAI_RGA-6509_1 uptime is 1 year, 6 weeks, 23 hours, 45 minutes
Time since C_QUAI_RGA-6509_1 switched to active is 1 year, 6 weeks, 23 hours, 47 minutes
System returned to ROM by reload (SP by reload)
System restarted at 17:04:42 WEST Sun Apr 1 2007
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-18.SXE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
ROUTER (R7000) processor (revision 2.0) with 458720K/65536K bytes of memory.
Processor board ID SCA042801ZP
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
34 Virtual Ethernet/IEEE 802.3 interfaces
24 FastEthernet/IEEE 802.3 interfaces
138 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Re: 6509 memory issues
Whats the memory error your seeing?
No error, just an alarm because i'm using 82% of the total memory...
ok, looking at the output you posted, it seems SNMP is your culprit. Do you have some monitoring software heavily polling this device?
Yes sure a few ones, should i need to just lower the snmp queries ?
It depends on the frequency and what exactly is being polled. Its hard to determine, but if you want to ensure only authorized snmp traffic you can setup an ACL.
145
