Bronze
6509 NEB A power supply not working
Dear All ,
The power supply on 6509 NEB A is not working with me . I have installed only one power supply on the box  WS-CAC-3000W
It is showing me that "Input OK , Output fail " from the LCD
I tried with another WS-CAC-3000W , another power source but still same problem .
Any Clues ?
Haris |P
Hi Haris,
Could you please try to put both the power supplies one by one on another slot and check if it works fine there? Please let me know the result of the workaround.
Barun
Bronze
Re: 6509 NEB A power supply not working
The Power Supply working after connecting both . And after some time i remove one powersupply and switch was working with one PS also . I didnt get this logic . Previously i tried single power supply on each slot but it didnt worked .
343
