6509 PC Card format failed in slot0
I might need to format or delete file into the PC Cards in 6509 slot0, but I can't do it.
I changed the PC Cards with a New and I've the same thing.
Anything suggestion ?
1 ACCEPTED SOLUTION
Re: 6509 PC Card format failed in slot0
You may have a faulty card and may need to be replaced. Which supervisor and software version are you running? Also check this field notice and see if it applies to you.
http://www.cisco.com/en/US/ts/fn/620/fn62466.html
Mark
Which CF card are you using? Have you tried formatting in another slot or supervisor?
Yes, but I can't do It, because I obtain the same result.
I used a "MEM-C64K-ATA-1-64M" memory card.
Is it correct ?
Mark
I've a Sup1a and It doesn't support the ATA PC CARD.
Best reguard
Hall of Fame Super Gold
I think it will only accept UP TO 2Gig Type III CF cards.
213
