Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
6509 port error
We have a 6509 connected to another 6509 via trunk port using 10G interface XENPAK-10GB-SR. The link went down with the following error message:
Aug 29 20:17:41.088 EST: %PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 4 is experiencing the following error: Port Asic 1: 28 important event
Aug 29 20:18:18.100 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet4/2, changed state to down
Aug 29 20:18:18.096 EST: %UDLD-SP-4-UDLD_PORT_DISABLED: UDLD disabled interface Te4/2, unidirectional link detected
Aug 29 20:18:18.096 EST: %PM-SP-4-ERR_DISABLE: udld error detected on Te4/2, putting Te4/2 in err-disable state
Aug 29 20:18:18.164 EST: %LINK-3-UPDOWN: Interface TenGigabitEthernet4/2, changed state to down
Aug 29 20:18:18.120 EST: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet4/2, changed state to down
Aug 29 20:18:18.168 EST: %LINK-SP-3-UPDOWN: Interface TenGigabitEthernet4/2, changed state to down
First, we check the fiber cable and the cable appears to be fine, replace the XENPAK-10GB-SR with a known working one, it's not work still, replaced the whole module it still having the same problem but this time the port showing down down instead of err-disabled.
Does anymore have any idea what could be the problem here?
Steve
Silver
Re: 6509 port error
The UDLD Protocol disabled an interface because it detected connections between neighbors that were functioning only in one direction, which might potentially cause spanning-tree loops or interfere with connectivity.
Also check Port Duplex and Speed , keepalive matching.
Dharmesh Purohit
Re: 6509 port error
I checked the port duplex and speed are the same on both side. Also hte keepalive is matching.
Re: 6509 port error
Steve,
This message indicates that the firmware of the module detected an error condition. The
error was related to an event ASIC 0. This is usually a transient error and nothing to
worry about. However, If you see these errors showing up repeatedly in the log, I would
suggest doing the steps below and it if continues you should replace the module.
Please reseat the card and see if that makes any change.
JG
Re: 6509 port error
Thanks JG,
I've reseated the card and replaced the module but makes no changes. The only thing that is different is that the port is now shown down down (notconnected), before it was err-disabled.
Steve
Re: 6509 port error
Steve,
Seems to be a BAD module, please get it RMA'd.
~JG
Please rate helpful posts
Re: 6509 port error
I replaced the module but same problem.
Steve
Re: 6509 port error
The strange thing about this is that three other ports on this module works find except for this one port. Is there anything else i can try.
Re: 6509 port error
Steve,
I have the same problem. I haven't been able to determine the exact problem. Have you?
Brian
Silver
Re: 6509 port error
Hey steve,
There is also one IOS problem.. Please also compare with your problem:
The following messages and a reload might occur on a WS-X6348-RJ-45 switching module:
%PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 3 is experiencing the following error: Qchip #1
reset because of FIFO freeze detect
Controller Ddr Sync Error
%PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 3 is experiencing the following error: Sculptor
Txif Sequence Error
%PM_SCP-SP-1-LCP_FW_ERR: System resetting module 3 to recover from error: Detected
persistent condition of blocked QChip #1 FIFO
This problem occurs at data rates lower than 10 pps. This problem is resolved in Release 12.2(18)SXF8. (CSCsh66367)
Please check...
Dharmesh Purohit
841
