Community Member
6509 RSAN ingress/egress point clarification
This was answered in a previous posting, but I am unclear on the answer,
According to Cisco documentation:
"Monitored Traffic Direction
You can configure local SPAN sessions, RSPAN source sessions, and ERSPAN source sessions to monitor ingress traffic (called ingress SPAN), or to monitor egress traffic (called egress SPAN), or to monitor traffic flowing in both directions.
Ingress SPAN copies traffic received by the source ports and VLANs for analysis at the destination port. Egress SPAN copies traffic transmitted from the source ports and VLANs. When you enter the both keyword, SPAN copies the traffic received and transmitted by the source ports and VLANs to the destination port."
I can understand how either direction of traffic on a single port is mirrored to the destination port.
But if you have a layer three switch and you desiginate the direction of traffic like so:
monitor session 1 source vlan 2-20 rx
monitor session 1 destination interface Gi1/1
Is the traffic mirrored from the layer 2 vlan or the SVI of the vlan on the switch?
If it is the layer 2 vlan, what is considered the "rx" direction point of the layer 2 vlan?
Is the inbound traffic to each individual port in vlans 2-20 mirrored to Gi1/1?
If it is the SVI of the vlan, would the mirrored traffic be the traffic received on the SVI from the devices in the vlan using the SVI as a default gateway?
Hall of Fame Super Silver
Re: 6509 RSAN ingress/egress point clarification
Hello Richard,
your understanding is correct or at least I share your ideas on this:
layer2 broadcast domain
yes
when using both you can see multiple copies of each frame on the sniffer trace: one copy as the frame is received on port x and one copy as frame is sent out port y in the same vlan
inter-vlan routing should appear once per vlan but if the packet is sent from vlan2 to vlan3 again you can see two different ethernet frames that actually carry the same IP packet inside (after the packet rewrite)
Hope to help
Giuseppe
Community Member
Thanks Guiseppe:
"inter-vlan routing should appear once per vlan but if the packet is sent from vlan2 to vlan3"
Sorry, but I am still not clear in the Vlan Interface tie in.
Wouldn't vlan2 sent to vlan3 be inter vlan routing?
So, are you saying a packet could show up three times when using "both"?:
1 time when leaving interface vlan2
1 time when leaving vlan2 port
1 time when entering vlan3 port
314
