Webcast-Catalyst9k
6509 show flash
Hello All,
Bit confused with output of show flash and show boot where is actual image used why it says slot0 in Boot and show version has image
'bootflash:BTSYNC_cat6000-supk8.7-6-10.bin
(enable) sh flash
-#- ED --type-- --crc--- -seek-- nlen -length- -----date/time------ name
  1 .. ffffffff bdfea4c9  a32d14   31 10431636 Jun 06 2005 13:48:47 BTSYNC_cat6000-supk8.7-6-10.bin
5559020 bytes available (10431764 bytes used)
EBRSW012> (enable)
(enable) sh boot
BOOT variable = bootflash:BTSYNC_cat6000-supk8.7-6-10.bin,1;slot0:ebrsw010\cat6000-supk8.7-6-10.bin,1;
6509 show flash
Hi Amit,
Try the following:
clear boot system flash slot0:ebrsw010\cat6000-supk8.7-6-10.bin
Richard
6509 show flash
Thansk Richard for reply please advise if this is service impacting command or only does refresh , also is there reboot required after this command ?
Amit
6509 show flash
Hi Amit,
This command is not service impacting.
I just clear out the second (wrong) boot variable. After the command show boot should just show the correct bootflash: entry. A reboot isn't needed for that, but maybe you have to save the config to see the change under show boot.
Richard
6509 show flash
Thanks Richard , It seems to   be working One query so "bootflash" is just name of a name remane of name of image or or is it a directory
(enable) sh flash
  1 .. ffffffff bdfea4c9  a32d14    9 10431636 Jun 14 2005 12:42:44 bootflash
> (enable) sh boot
BOOT variable = bootflash:bootflash,1;
CONFIG_FILE variable = bootflash:switch.cfg
Configuration register is 0x2
ignore-config: disabled
auto-config: non-recurring, overwrite, sync disabled
ROMMON console baud: 9600
boot: image specified by the boot system commands
6509 show flash
could you post the output of:
dir bootflash:
I think this should also work under catos.
Richard
6509 show flash
Please find output below
> (enable) dir bootflash:
-#- -length- -----date/time------ name
  1 10431636 Jun 14 2005 12:42:44 bootflash
6509 show flash
Is this a different device?
what is the output of
dir bootflash:bootflash/
Re: 6509 show flash
hello Richard ,
Yes its different switch , please find output below
(enable) dir bootflash:bootflash/
No such file
If any one can reply please
6509 show flash
Hello ,
If anyone can help please
amit
325
