6509 Sup HOT in rommon
hi, i have a Cisco 6509 and after to introduce the command "hw-module module 6 reset" in order to perform a reset, this module turn to rommon mode.
after that if I introduce de comand "boot" the module turn in HOT STANBY mode.
I attach some captures.
Regards.
1 REPLY
Re: 6509 Sup HOT in rommon
Is the configuration register set correctly on the standby's SP?  Please do the following and attach the output -
1) attach 6
2) show version
Your output also suggests that the standby console is disabled so you may need to enable it from the active SUP before trying to run 'show version' from the standby card -
Router(config)#redundancy
Router(config..)#main-cpu
Router(config..)#standby console enable
227
