6509 sup1A issue
Dear All,
I am testing the sup1A in my test bed with only chassis without any line modules. I am getting the following console errors.I have ios image and bootldr in the pc card (slot0:)
From sp Rommon after the cmd "BOOT=slot0:c6sup11.......... " it boots and terminated in RP Rommon with the error related to bootldr missing in bootflash of RP. Please help me how to copy the bootldr image in the pc card to the RP bootflash: also how to solve this above issue
The console message as below:
Fred > dir slot0:
File size Checksum File name
17661700 bytes (0x10d7f04) 0x56616541 c6sup11-jsv-mz.121-26.E3
1916864 bytes (0x1d3fc0) 0x7ae1ddef c6msfc-boot-mz.121-26.E3.bin
fred > dir bootflash:
fred > set
config_gile=
config_file=
CONFIG_FILE=
SLOTCACHE=cards;
PNCL_2=2
PS1=fred >
boot=
BOOT=slot0:c6sup11-jsv-mz.121-26.E3
BOOTLDR=
BSI=0
PNCL_1=2
CRASHINFO=crashinfo_FAILED
RET_2_RTS=14:46:21 UTC Tue Oct 17 2006
RET_2_RCALTS=1161096382
?=0
fred > confreg 0x2102
You must reset or power cycle for new config to take effect
fred > reset
System Bootstrap, Version 5.3(2)
Copyright (c) 1994-2002 by cisco Systems, Inc.
c6k_sup1 processor with 65536 Kbytes of main memory
Autoboot executing command: "boot slot0:c6sup11-jsv-mz.121-26.E3"
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################################ [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) c6sup1_sp Software (c6sup1_sp-SPV-M), Version 12.1(26)E3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 16-Aug-05 00:25 by ccai
Image text-base: 0x60020F90, data-base: 0x60844000
00:00:03: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:03: %OIR-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.0(3)XE, RELEASE SOFTWARE
Copyright (c) 1998 by cisco Systems, Inc.
Cat6k-MSFC platform with 131072 Kbytes of main memory
open failed due to full file table
loadprog: error - on file open
open: failed to find and/or load the bootloader: "slot0:c6msfc-boot-mz.121-26.E3.bin"
26.E3.bin"
boot: cannot load "cisco2-Cat6k-MSFC"
boot: cannot determine first file name on device "bootflash:"
System Bootstrap, Version 12.0(3)XE, Incboot: cannot determine first file name on device "bootflash:"
thanks
swamy
Re: 6509 sup1A issue
Hi Swamy,
I belive you do not have boot image on your msfc bootflash.
If you don't, you need to have boot loader file at least in the MSFC bootflash to boot up. If this is the case, please xmodem the proper boot loader for MSFC first.
Once you have bootloader file either in bootflash or via xmodem, you should be able to boot up usingPCMCIA card.
Please beware that if you did xmodem, this doesn't actually copy to MSFC bootflash so
you would need to copy it later.
Ankur
Ankur,
Please tell me If after the xmodem copy,where the file will be? How can I copy it to the bootflash?
I confused about the xmodem destination location for the bootldr image.
Please help me
swamy
Hi Swamy,
After xmodem the image will be in DRAM of RP and it will just boot the RP and once it boots then you can tftp the boot loader image into bootflash of RP.
Ankur
* Pls rate all helpfull post
Ankur,
Bit confuse. If the bootldr in the RP DRAM then how can I tftp to the RP bootflash:
For Tftp to work the image should be in the local drive of the PC.
Please explain me.
I will rate soon.
swamy
Ankur,
In my pc card slot0: i have both IOS image and the bootldr image. I need to copy this bootldr to the RP bootflash:.
Please confirm me is it possible or as you said xmodem is the only solution. If xmodem only then please answer my reply to ur anohter message.
thanks
swamy
Hi Swamy,
You can first try copy from sup-slot0: and if that does not work then try xmodem.
Also you have 2 image so you only need to copy the bootloader image to the bootflash of RP.
Ankur
Dear,
I tried the sup-slot0 command with no auccess.so only left is xmodem
swamy
Hi Swamy,
From where do you tried or issued this command? You should be in RP rommon before issuing this command.
dir sup-slot0: will not work but copy command should work.
If you have already done this and still you cannot copy then xmodem the boo tloader when you are in RP rommon and once xmodem is complted it will copy the image into RP DRAM and RP DRAM will bot and once you see the RP boot prompt you can tftp the bot image into RP bootflash.
I hope I am bale to explain.
Ankur
Dear ankur,
Let me downlaod the image.
swamy
Ankur,
Please correct me if i am wrong.
BOOTLDR=bootflash:c6msfc-boot-mz.121-26.E3.bin
Should the .bin be there or not.
swamy
Hi Swamy,
No worry. So now your bootloader is into bootflash? Were you able to xmodem successfully or copy commadn worked?
Ankur
804
