Community Member
6509 switch blade shows power down
Hello Guys, i have one of my switch modules that shows PwrDown when i issue the command show mod.
Mod Ports Card Type                              Model              Serial No.
1    9  Supervisor Engine 32 8GE (Active)      WS-SUP32-GE-3B     SAD09120263
2   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-TX     SAL1029VWZ5
3   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL104681AW
Mod MAC addresses                       Hw    Fw           Sw           Status
1  0011.5ce1.8e64 to 0011.5ce1.8e6f   4.1   12.2(18r)SX2 12.2(33)SXI2 Ok
2  000a.b843.ca10 to 000a.b843.ca3f   7.0   7.2(1)       12.2(33)SXI2 Ok
3  0019.aa98.90c8 to 0019.aa98.90d7   4.5   7.2(1)       12.2(33)SXI2
PwrDown
Mod  Sub-Module                  Model              Serial       Hw     Status
1  Policy Feature Card 3       WS-F6K-PFC3B       SAD091601CM  2.1    Ok
1  Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A      SAD091504C1  3.0    Ok
Mod  Online Diag Status
1  Pass
2  Pass
3  Not Applicable
i tried disabling the diagnostic monitor for the module, did a power enable module command and then reset it but it still fails.
this is the third blade that i am replacing in a few weeks and i still get the same error. i am persuded that it is not a hardware since it is the third blade in a matter of weeks.
after the module reset, i receive this error % module 3 is operationally off (FRU-power failed)
could an ios upgrade solve this issue? are there any ios related bugs?
thanks for the help.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Apr 18 08:13:08.046 CET: %OIR-SP-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure.
I think you should open a TAC Case.  You've got a hardware failure with the line card.  Please include the "sh log" that you've posted with the TAC Case.
VIP Super Bronze
If you are having problem with multiple blades in the same slot, take a flash light have a look at the pins in the back of the chassis and make sure the pins on the backplane are not bend.  You are running a very old IOS (SXI2).  If I remember correctly, this version was differed, so it is a good idea to load a newer version, but I don't think that is your issue.
Purple
  Seeing you have 6 open slots have you tried any slot besides 3 ?   If you run it in one of the other slots and its ok then you know it is an issue in the chassis slot .
Correct me if I'm wrong here, but I believe the 6516 line card is NOT COMPATIBLE with the Sup32.
Purple
Re: 6509 switch blade shows power down
   Think he is ok , I would try a different slot and see what happens.For sup32 he needs 12.2 SXF code , he is running SXI code.
WS-X6516A-GBIC 16-Port Gigabit Ethernet GBIC Switching Module
Product ID
(append "=" for spares)
Product Description
Minimum
Software
Versions
WS-X6516A-GBIC
16-port Gigabit Ethernet GBIC
dCEF256 with a DFC
CEF256
1-MB per-port packet buffers
Supports egress multicast replication
QoS port architecture (Rx/Tx): 1p1q4t/1p2q2t
Number of ports: 16
Number of port groups: 2
Port ranges per port group: 1-8, 9-16
With Supervisor Engine 720-10GE
12.2(33)SXH
12.2(14)SX
With Supervisor Engine 32
12.2(18)SXF
Oh cool!  Thanks Glen.
Now that Glen has shown me that the module works with Sup32, can I ask if you console to the chassis, reseat the blade and post the entire bootup process of this line card?
Community Member
Hello all and thanks for you helpful post.
@leolaohoo, the output is below. when the slot is placed in another chassis, it work. so it is more likely a defected backplane. all the pins seem normal
Apr 18 08:13:05.491 CET: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
Apr 18 08:13:08.046 CET: %OIR-SP-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure. PMB registers are dumped as follows,  R0= 0x0, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x1, R6= 0x0, R7= 0x1, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
Apr 18 08:13:08.046 CET: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (FRU-power failed)
Apr 18 08:13:35.373 CET: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
Apr 18 08:13:38.469 CET: %OIR-SP-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure. PMB registers are dumped as follows,  R0= 0x0, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x1, R6= 0x0, R7= 0x1, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
Apr 18 08:13:38.469 CET: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (FRU-power failed)
Apr 18 08:14:04.627 CET: %OIR-SP-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure. PMB registers are dumped as follows,  R0= 0x0, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x1, R6= 0x0, R7= 0x1, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
Apr 18 08:14:04.627 CET: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (FRU-power failed)
Apr 18 08:14:31.084 CET: %OIR-SP-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure. PMB registers are dumped as follows,  R0= 0x0, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x1, R6= 0x0, R7= 0x1, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
Apr 18 08:14:31.084 CET: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (FRU-power failed)
Apr 18 08:14:57.223 CET: %OIR-SP-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure. PMB registers are dumped as follows,  R0= 0x0, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x1, R6= 0x0, R7= 0x1, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
Apr 18 08:14:57.223 CET: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (FRU-power failed)
i think i should open a TAC case.
Community Member
thanks for your help !
Thanks for the ratings.
3010
