Webcast-Catalyst9k
6509 switch
Can someone tell me why I can't access my 6509 by telnet or console?
It's saying "Access not permitted. Closing connection." Even if I have the username and password for the switch.
Onin
Re: 6509 switch
Hi Ninora,
you get the message only while telneting the
switch or even for console also?
configured TACACS or RADIUS?
lemme know the status.
Re: 6509 switch
I'm getting the message on both (telnet and console). It's configured on TACACS also.
Thanks for the reply and hope you can help me.
God Bless..
-= Onin =-
Re: 6509 switch
HI
May be u have configured some access-list.can u check it.
Mahmood
Re: 6509 switch
make sure on the TACACS server 6509 has been configured as a member, bcoz some times what happens is, if the TACACS commands are issued in the switches, but didn't make 6509 as a member in TACACS, u will face such kind of probz.
Re: 6509 switch
It's possible that a timeout value is not specified for Telnet or the console.
Re: 6509 switch
I used to access it before. How is that possible. But anyways, thanks for the reply.
So, password recovery won't work also?
124
