6509 to 2960 port-channel limit?
Hello.  We are looking to connect a 2960 switch to our 6509 using an etherchannel/port-channel group.  Is there a limit on the number of physical ports that can participate in a single port-channel group?  Thanks for the help!
Hall of Fame Super Blue
Re: 6509 to 2960 port-channel limit?
Yes, you can have a maximum of 8 physical ports in the etherchannel bundle. They need to the the same speed/duplex.
Jon
Thank you very much.....yes, we will be connecting all the ports over gigabit ethernet
Hall of Fame Super Gold
Minimum of 2 and a maximum of 8.
Purple
  Be aware that the 2960 will only support a total of 6 etherchannels per switch.
Silver
ans has already been provided by others however, for future ref check the release notes and you will get everything you are looking for
Varun
4155
