Community Member
6509 - Upgrading to SUP2 cards
I recently bought two SUP2 cards, fully loaded with mem/pfc and MSFC2.
Currently running Sup1A's with PFC and MSFC2's. Is there anything special I need to worry about or is it just a matter of installing the newer SUPS and uploading the configs to them ?
Dave
1 REPLY
Re: 6509 - Upgrading to SUP2 cards
Hi Dave,
I am not sure your sup1a's were having Native IOS or CATOS? So just make sure before installing both the sup2s in your chassis if you were earlier having Native IOS just convert your new sups also with Native IOS one by one and once both the sups are done you can upload your config to them.
Incase you were earlier having CATOS only on your sup1a then you can simply load them into the chassis and upload your configs.
Ankur
*Pls rate all helpfull post
123
