12-14-2011 12:07 PM - edited 03-07-2019 03:54 AM
Hello all,
I have been stuck for the past couple days with sup2's that will not boot, xmodem transfers fail every time, and from what i can gather my supervisor is stuck in a constant state of sp rommon mode. I have been wading through the hundreds of topics with no resolution that works. here is a sample of what i am seeing:
System Bootstrap, Version 6.1(3)
Copyright (c) 1994-2000 by cisco Systems, Inc.
c6k_sup2 processor with 131072 Kbytes of main memory
Autoboot executing command: "boot "
boot: cannot determine first file name on device "bootflash:"
rommon 1 >
Any help would be awesome!
Thomas
12-14-2011 01:30 PM
Please reboot the Sup card and post the entire bootup process so we can determine WHERE exactly is the issue.
10-31-2012 01:49 AM
Have the same problem.
Problem begin after a month's inactivity of catalyst 6509. I was not be able to boot cisco with previous configuration. It was loaded only with old image that was on bootflash:. So I deleted it and now have same trouble as topicstarter.
rommon 1 > dir bootflash:
File size Checksum File name
25244176 bytes (0x1813210) 0x193f49ab c6sup22-pk2sv-mz.121-20.E3 (deleted)
246120 bytes (0x3c168) 0x293adcca crashinfo_20111106-090411 (deleted)
266117 bytes (0x40f85) 0x44b71a4b crashinfo_20120615-110212 (deleted)
267664 bytes (0x41590) 0x901ea50b crashinfo_20120615-110824 (deleted)
656 bytes (0x290) 0x66858b84 diaginfo_mod9_20120717-092207 (deleted)
1600884 bytes (0x186d74) 0x6031ac06 c6msfc2-boot-mz.121-3a.E4 (deleted)
How can I undelete last file? I think this will solve the problem
Here is a full log of boot:
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Reading monitor variables from NVRAM
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
c6k_sup2 processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:"
Clearing bss
Enabling interrupts
Initializing TLB
Initializing cache
Sizing NVRAM
Exiting init
rommon 1 >
And one more thing. Maybe it would be usefull:
rommon 2 > dir slot0:
device does not contain a valid magic number
dir: cannot open device "slot0:"
Don't know if it is ok. I had trying to boot from pcmcia card:
rommon 3 > dev
Devices in device table:
id name
bootflash: boot flash
slot0: PCMCIA slot 0
eprom: eprom
rommon 4 > boot slot0:
boot: cannot open "slot0:"
boot: cannot determine first file name on device "slot0:"
10-31-2012 11:59 PM
Trying to follow this instructions
I don't understand where from images appear in bootflash: in step 5.
11-01-2012 06:46 AM
In my first message I wrote log of boot. But it wasn't first boot. Here is first boot. Has some differences:
Clearing bss
Warning: Rommon NVRAM area is corrupted. Initialize the area to default values
Enabling interrupts
Initializing TLB
Initializing cache
Sizing NVRAM
Exiting init
Maybe this is the problem? What to do?
11-01-2012 03:17 PM
I think you need to contact Cisco TAC. You need to RMA the supervisor card.
