01-14-2010 08:49 AM - edited 03-06-2019 09:17 AM
This has always bugged me. If I remove a 48 port ethernet module from a 6509E permanently, the configuration will stay in the configuration until i pop a new card in. Is there a way to clear the old configutation from running and start?
Solved! Go to Solution.
01-14-2010 09:00 AM
Yes.
Use the module clear-config command as specified in
01-14-2010 09:00 AM
Yes.
01-14-2010 09:20 AM
Great, thanks a lot.
