6509E-VSS high CPU process due to ARP input
eek
We are experiencing with high CPU input due to ARP input between 20:30 and 22:30 every day
At this time we have a lot of backup operations. When I look the netflow report, I can't see anything anormal.
We are changing our backup server's NIC card from 1gig to 10Gig. The backup operation's traffic is high (approx 2Gbps level) but 6509 has to be handle this size of traffic.
We are using two 6509E in VSS mode
and our image version is  s72033-adventerprisek9_wan-mz.122-33.SXJ.bin
What the problem cause may be?
20:00
  show ip arp summary
  2588 IP ARP entries, with 166 of them incomplete
   show process cpu sorted
  CPU utilization for five seconds: 11%/3%; one minute: 9%; five minutes: 10%
   PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
     3         124       130        953  1.67%  0.13%  0.02%   6 SSH Process
     9     7713920    452047      17064  1.19%  0.47%  0.37%   0 Check heaps
   306    45535792 118795990        383  0.79%  0.73%  0.73%   0 Earl NDE Task
   327    18046456 124766366        144  0.71%  0.54%  0.50%   0 IP Input
   558     9185532  35575478        258  0.71%  0.36%  0.35%   0 Port manager per
    12   263195052 123093541       2138  0.47%  0.52%  0.55%   0 ARP Input
20:30
  show ip arp summary
  2587 IP ARP entries, with 165 of them incomplete
  CPU utilization for five seconds: 88%/29%; one minute: 82%; five minutes: 83%
    12   263956908 123363086       2139 42.39% 39.49% 40.28%   0 ARP Input
   397    26557084  28759093        923  4.71%  4.33%  4.32%   0 XDR mcast
     9     7721604    452477      17065  3.11%  0.52%  0.38%   0 Check heaps
   306    45582404 118903810        383  2.79%  2.38%  2.00%   0 Earl NDE Task
     3         168       130       1292  1.67%  0.13%  0.02%   6 SSH Process
21:00
show ip arp summary
  2589 IP ARP entries, with 167 of them incomplete
  CPU utilization for five seconds: 81%/27%; one minute: 83%; five minutes: 79%
    12   265046164 123738558       2141 37.91% 39.18% 37.08%   0 ARP Input
   397    26664908  28858941        923  5.43%  4.55%  4.26%   0 XDR mcast
   306    45645772 119037173        383  3.11%  2.09%  1.95%   0 Earl NDE Task
     3         176       130       1353  1.67%  0.13%  0.02%   6 SSH Process
   327    18089292 124960978        144  1.11%  0.71%  0.70%   0 IP Input
21:30
  show ip arp summary
  2589 IP ARP entries, with 168 of them incomplete
  CPU utilization for five seconds: 98%/40%; one minute: 83%; five minutes: 79%
    12   266025804 124084184       2143 41.67% 37.30% 36.26%   0 ARP Input
   397    26760700  28950445        924  4.07%  3.98%  3.92%   0 XDR mcast
    24    18692320 127459398        146  1.75%  1.07%  0.83%   0 IPC Seat Manager
     3         160       130       1230  1.67%  0.13%  0.02%   6 SSH Process
   327    18110704 125057205        144  1.27%  0.78%  0.70%   0 IP Input
22:00
  show ip arp summary
  2586 IP ARP entries, with 164 of them incomplete
  CPU utilization for five seconds: 23%/9%; one minute: 65%; five minutes: 72%
    12   266948752 124452798       2144  7.27% 28.77% 32.71%   0 ARP Input
     3         144       130       1107  1.67%  0.13%  0.02%   6 SSH Process
   306    45782092 119315110        383  1.59%  2.04%  2.08%   0 Earl NDE Task
   397    26863336  29062080        924  1.11%  3.87%  4.44%   0 XDR mcast
   327    18132460 125159162        144  0.79%  0.66%  0.69%   0 IP Input
16 Replies 16
Hi ,
You can check :
sh ip traffic | s ARP
Also you can use control-plane policy for ARP :
mls qos protocol ARP police
Dan
Hi, thanks for your answer,
When I look for ip traffic, I see that Receive Replies is increasing rapidly..
C6509-251-DC#clear ip traffic
Clear "show ip traffic" counters [confirm]
C6509-251-DC#
C6509-251-DC#
C6509-251-DC#
C6509-251-DC#
C6509-251-DC#sh ip traffic | s ARP
ARP statistics:
  Rcvd: 36 requests, 8199 replies, 3 reverse, 0 other
  Sent: 14 requests, 8 replies (0 proxy), 0 reverse
  Drop due to input queue full: 0
C6509-251-DC#
C6509-251-DC#
ARP statistics:
  Rcvd: 77 requests, 21586 replies, 11 reverse, 0 other
  Sent: 61 requests, 22 replies (0 proxy), 0 reverse
C6509-251-DC#
C6509-251-DC#
C6509-251-DC#
ARP statistics:
  Rcvd: 228 requests, 57298 replies, 24 reverse, 0 other
  Sent: 213 requests, 77 replies (2 proxy), 0 reverse
C6509-251-DC#
C6509-251-DC#
C6509-251-DC#
C6509-251-DC#
ARP statistics:
  Rcvd: 335 requests, 82834 replies, 31 reverse, 0 other
  Sent: 344 requests, 114 replies (5 proxy), 0 reverse
C6509-251-DC#
C6509-251-DC#
C6509-251-DC#
ARP statistics:
  Rcvd: 482 requests, 121919 replies, 46 reverse, 0 other
  Sent: 491 requests, 166 replies (6 proxy), 0 reverse
Erdal
At normal time (when CPU traffic is normal)
this ARP reply count is not increasing;
C6509-251-DC#show ip traffic | section ARP
ARP statistics:
  Rcvd: 161 requests, 0 replies, 17 reverse, 0 other
  Sent: 33 requests, 57 replies (2 proxy), 0 reverse
ARP statistics:
  Rcvd: 199 requests, 0 replies, 22 reverse, 0 other
  Sent: 38 requests, 75 replies (2 proxy), 0 reverse
ARP statistics:
  Rcvd: 206 requests, 0 replies, 22 reverse, 0 other
  Sent: 44 requests, 78 replies (2 proxy), 0 reverse
ARP statistics:
  Rcvd: 211 requests, 0 replies, 23 reverse, 0 other
  Sent: 46 requests, 78 replies (2 proxy), 0 reverse
ARP statistics:
  Rcvd: 277 requests, 0 replies, 25 reverse, 0 other
  Sent: 49 requests, 137 replies (35 proxy), 0 reverse
ARP statistics:
  Rcvd: 295 requests, 0 replies, 25 reverse, 0 other
  Sent: 61 requests, 143 replies (35 proxy), 0 reverse
Hi ,
You could apply the ARP rate limit, but first of all you must know where are they from :
show interfaces accounting | i Ethe|ARP|Vlan
The second column will show you the number of packets IN. I would try using accounting identify the source VLAN and also source interface.
Dan
I get this output;
Vlan1 VL001(MGMT)
                Protocol    PktsIn   CharsIn   PktsOut  CharsOut
                   Other        160       9600          0          0
                      IP  388089272 282981891991  253012817 134920433824
                 DECMOP        418      32186        142      18318
                     ARP      47795    2960482      30521    3418352
Vlan2 VL002
                   Other         10        600          0          0
                      IP 1933102896 727656700757 4009256393 5467437676205
                 DECMOP        125       9625        142      18318
                     ARP   82061561 4923744674     496931   55656272
and export to excel and sorted, I see the ARP input is coming from VLAN2, I will try to get info when the problem occour (22:00 PM at GMT+2)
ProtocolPktsInCharsInPktsOutCharsOut
Vlan2ARP82061561492374467449693155656272
Vlan111ARP35143321113488562526300224
Vlan211ARP2656591593954010019611221952
Vlan102ARP1402058412432181562033472
Vlan110ARP1135486812880781638754256
unfurtunately I cannot see any arp traffic on Layer2 ports, how can i find the source of this arp packet?
Whould I have to enable anything to apply ARP rate limit or  "mls qos protocol ARP police" is enoug for
I want to ask this, how can I clear this counters?
Regards..
Hi ,
Clear : clear counters
To enable arp rate-limit you need to enable "mls qos".
Dan
You might try , having in mind that you now know that the problem is on Vlan 2 , using :
show buffers input-interface vlan2
Dan
I configured
mls qos protocol ARP police 64000
but it was distrupt the treaffic, so i had to be remove command.
i thing i has to be configure the correct value, which value whould i use?
this is the show buffers command;
C6509-251-DC#show buffers input-interface vlan 2
  Header DataArea  Pool Rcnt  Size Link  Enc    Flags          Input      Output
47950894  802BCA4 Small    1    60    1    1      200            Vl2        None
47950C28  802BF64 Small    1    60    1    1      200            Vl2        None
479521A0  802CFE4 Small    1    60    1    1      200            Vl2        None
47952534  802D2A4 Small    1    60    1    1      200            Vl2        None
47953E40  802E5E4 Small    1    60    1    1      200            Vl2        None
4795659C  8030424 Small    1    60    1    1      200            Vl2        None
47956930  80306E4 Small    1    60    1    1      200            Vl2        None
4795823C  8031A24 Small    1    60    1    1      200            Vl2        None
4795A998  8033864 Small    1    60    1    1      200            Vl2        None
4795C9CC  8035124 Small    1    60    1    1      200            Vl2        None
4795E2D8  8036464 Small    1    60    1    1      200            Vl2        None
4795F128  8036F64 Small    1    60    1    1      200            Vl2        None
47964E30  803B6E4 Small    1    60    1    1      200            Vl2        None
47965C80  803C1E4 Small    1    60    1    1      200            Vl2        None
47966E64  803CFA4 Small    1    60    1    1      200            Vl2        None
4796A7A4  803FBA4 Small    1    60    1    1      200            Vl2        None
4796AECC  8040124 Small    1    60    1    1      200            Vl2        None
479704AC  8044324 Small    1    60    1    1      200            Vl2        None
47974180  80471E4 Small    1    60    1    1      200            Vl2        None
4797C978  804DA64 Small    1    60    1    1      200            Vl2        None
4797E618  804F064 Small    1    60    1    1      200            Vl2        None
479822EC  8051F24 Small    1    60    1    1      200            Vl2        None
479846B4  8053AA4 Small    1    60    1    1      200            Vl2        None
47989900  80579E4 Small    1    60    1    1      200            Vl2        None
4798C05C  8059824 Small    1    60    1    1      200            Vl2        None
4798D968  805AB64 Small    1    60    1    1      200            Vl2        None
4799248C  805E524 Small    1    60    1    1      200            Vl2        None
479956A4  8060BA4 Small    1    60    1    1      200            Vl2        None
47996FB0  8061EE4 Small    1    60    1    1      200            Vl2        None
479AC39C  8072424 Small    1    60    1    1      200            Vl2        None
479AC730  80726E4 Small    1    60    1    1      200            Vl2        None
479B197C  8076624 Small    1    60    1    1      200            Vl2        None
479B2EF4  80776A4 Small    1    60    1    1      200            Vl2        None
479B40D8  8078464 Small    1    60    1    1      200            Vl2        None
479B52BC  8079224 Small    1    60    1    1      200            Vl2        None
479B9DE0  807CBE4 Small    1    60    1    1      200            Vl2        None
479BAFC4  807D9A4 Small    1    60    1    1      200            Vl2        None
479BCC64  807EFA4 Small    1    60    1    1      200            Vl2        None
479BCFF8  807F264 Small    1    60    1    1      200            Vl2        None
  Header DataArea  Pool           Rcnt  Size  Original   Flags   caller_pc
There is no "correct" value, the value is linked with how many hosts are behind this system.
Let's try:
int vlan 2
ip accounting mac-address input
exit
show int vl 2 mac-accounting
Dan
When i use this command i cant see any anomal trafic at input way, i see anarmous traffic on output side.
When I track this ip address, i saw that this is out backup servers mac address...
directionmacpacketsbyteslast seen
output    0000.c9f2.f38a(66 )3831844 5813M last: 8340ms ago
output    0000.c9f2.f38e(70 )3745234 5681M last: 6252ms ago
output    e41f.1331.4890(1  )6763133061779 last: 6248ms ago
output    001a.64c1.d544(46 )3394110921794 last: 6252ms ago
output    5cf3.fc0b.e724(155)310558412955 last: 972ms ago
output    e41f.13b3.b6f8(21 )2898614008037 last: 6248ms ago
Yes, backup server can be able to get great trafficbut how the 6500 can't be able to handle this size of traffic?
As I understood until now , you problem is INPUT traffic , explicitly ARP Input on Vlan 2.
So I do not belive that the accounted traffic is the one that generates the issue.
Also until now , I've understand that you issue is interminttent , am I right ?
Dan
I see that you have a great deal of traffic punted to the CPU at the time of the issue, you can try to use
"debug netdr capture" to see what packets are getting to the CPU, it will give you more info on the flow
https://supportforums.cisco.com/docs/DOC-15608
cheers
Dejan
Yes our problem is occours specially at backup time, between 20:30 PM to 22:30 PM and, 00:30 AM to 02:30 AM.
Other than this time range, we have no problem. Also this CPU problem is not interrupting normal traffic at this specific time range..
