6513 Chassis's VSS
Hello Guys,
I had a question regarding the optimal setup for dual 6500's with supervisor modules using VSS. I know with one 6500 with two supervisor modules, you are exposed as far as a chassis failure goes, but if I introduce another chassis into the infrastructure do I then need to purchase two more supervisor modules or could I take one sup from the current and put it into the new chassis?
Thanks in advance guys!
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Super Bronze
Re: 6513 Chassis's VSS
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You can move the sup, unless you want to use quad sups with VSS.
Super Bronze
Disclaimer
Posting
6513 Chassis's VSS
Agree with Joseph. Remove the Standby Sup and placed it on to the other secondary device.
Inayath
6513 Chassis's VSS
thanks for the help guys!
110
