Webcast-Catalyst9k
6550 Switch 1000BastT module installation
hi,
i installed one WS-X6148-GE-TX on 13th slot of a 6513 while it was powered on. After detecting the module, the "show module" shows '48 unknown FRU type (major = 0x6003, mino".
Does the swithc require a reboot, does it have any minimum IOS version requirement ?
THe SUP engine is Catalyst 6000 supervisor 2 (Active) (WS-X6K-SUP2-2GE).
thanks
Re: 6550 Switch 1000BastT module installation
Hi Friend,
You need minimum 12.1(19)E1 release to support this card. Which release are you running on your sup?
Ankur
Purple
If its running catos you need at least code version 7.6.1 to support the card.
472
