6608 error
6608 often gets the following error if the port is not configured.
SYS-4-MODHPRESET:Host process (860)
As soon as the port is configured, no more error. How to fix this? Thanks
Silver
Re: 6608 error
That's normal. Your best bet is to configure all of the ports in CM, even if you don't plan to use them.
More info is at the following link:
http://www.cisco.com/warp/public/788/signalling/pri_troubleshooting.html
-Eric
Please remember to rate all helpful posts.
Re: 6608 error
Take a look at this link : http://www.cisco.com/en/US/customer/products/hw/switches/ps700/products_tech_note09186a008014f550.shtml#subtopic1m
...The workaround is to disable unused ports. Issue the set port disable mod/port command...
Jocelyn Neto
173
