12-30-2008 10:20 AM - edited 03-06-2019 03:11 AM
Hi, How the CEF Modules and Classic modules change pkt inside of 6500 chassis. They use the 32 Gbps Bus ? . TIA
Solved! Go to Solution.
12-30-2008 10:26 AM
Alexandre,
The 6500 White Paper should help you understand how the packet flows depending on the module inserted in the chassis
Please do take a moment to read all its content.
HTH,
__
Edison.
12-30-2008 10:23 AM
Alexandre
Could you clarify what you are asking - the 67xx do not and cannot use the 32Gbps shared bus as they are fabric only cards.
Jon
12-30-2008 10:39 AM
Dear Jon,
I mean, If I have in the same chassis 01 61xx module and 01 67xx module and 01 Sup CEF720. Will the Sup720 to connect the 32Bus to 720 Matrix ? Once more TKS - Alexandre
12-30-2008 10:40 AM
Alexandre
The Supervisor has connections to both the 32Gbps classic bus and to the cross bar switch fabric. It has to so it can communicate with the different type of modules in the chassis.
Jon
12-30-2008 10:26 AM
Alexandre,
HTH,
__
Edison.
