05-26-2008 09:12 AM - edited 03-05-2019 11:13 PM
Hi Guys,
Can i configure vlans , VTP and spanning tree in 7206 routers? and can i advertise vlans created in 7206 routers to 3550 switches?
can any body give me URL of sample configuration so i can study the same.
can any body tell me how can i physically connect 7206 router and 3550 swithces ?
Thanks in advance
05-26-2008 09:19 AM
Sorry, you can't.
__
Edison.
05-26-2008 09:32 AM
Thanks for your reply,
what about the physical connectivity between 7206 and 3550 ?
Thanks in advance
05-26-2008 10:10 AM
Yes, physical connectivity can be done:
For instance in the 3550:
switch(config)#vlan 72 name test
switch(config)#exit
switch(config)#interface vlan 72
switch(config-if)#ip address 192.168.1.2 255.255.255.0
switch(config)#interface fx/x
switch(config-if)#description port connecting to 7206
switch(config-if)#switchport mode access
switch(config-if)#switchport access vlan 72
On the router:
router(config)#interface fx/x
router(config-if)#ip address 192.168.1.1 255.255.255.0
You should be able to ping the switch from the router and vice-versa.
HTH,
__
Edison.
Please rate helpful posts
05-27-2008 10:34 AM
hi edison,
Thanks , if i am not wrong , sfp modul for 7206 is available so LC To SC i can connect to my 3550 switch.
still confused about the VLAN config. for 7206 . if u have any URL to study can you please send me that.
Thanks in Advance
05-27-2008 01:22 PM
You don't configure Vlans in the 7206. You are using a routed port which connects directly to the 3550.
The 7206 should have a copper port, does it not? You only have a fiber port in the 7206? That's very strange.
