10-22-2013 06:12 AM - edited 03-07-2019 04:10 PM
someone knows if Cisco 7304-MSC-100 SPA Carrier Card Line is it hot swappable?
I didn't find nothing on Cisco site.
Thank you
Marco
Solved! Go to Solution.
10-22-2013 08:59 AM
Hello Marco,
The Cisco 7304-MSC-100 card is suitable for Online Insertion & Removal (OIR). Kindly find the procedure described in the below link.
Hope this helps.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
10-22-2013 08:59 AM
Hello Marco,
Hope this helps.
Thanks & Regards,
Vignesh R P
