7304 router ethernet interface config problem
I am trying to do a simple config on gigabit ethernet interface of 7304 router. It does not give option for configuring speed,duplex, media. The interface is down/down. I configured IP address and tried everything but it is not coming up. Here is some useful config output. Any thoughts!!
Router#sh ver
Cisco IOS Software, 7300 Software (C7300-IS-M), Version 12.2(28)SB8, RELEASE SOFTWARE (fc1)
cisco 7300 (NSE100) processor (revision E) with 491520K/32768K bytes of memory.
Processor board ID SMQ1141NDD3
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
4 slot midplane, Version 69.48
1 FastEthernet interface
2 Gigabit Ethernet interfaces
2 Packet over SONET interfaces
509K bytes of non-volatile configuration memory.
125440K bytes of ATA compact flash in bootdisk (Sector size 512 bytes).
250880K bytes of ATA compact flash in disk0 (Sector size 512 bytes).
Router(config)#int gi0/0
Router(config-if)#?
Interface configuration commands:
access-expression Build a bridge boolean access expression
arp Set arp type (arpa, probe, snap) or timeout
backup Modify backup parameters
bandwidth Set bandwidth informational parameter
bgp-policy Apply policy propogated by bgp community string
bridge-group Transparent bridging interface parameters
carrier-delay Specify delay for interface transitions
cdp CDP interface subcommands
channel-group Add this interface to an Etherchannel group
clns CLNS interface subcommands
cmns OSI CMNS
default Set a command to its defaults
delay Specify interface throughput delay
description Interface specific description
dot1q dot1q interface configuration commands
dspu Down Stream PU
exit Exit from interface configuration mode
fair-queue Enable Fair Queuing on an Interface
glbp Gateway Load Balancing Protocol interface commands
help Description of the interactive help system
hold-queue Set hold queue depth
ip Interface Internet Protocol config commands
ipv6 IPv6 interface subcommands
isis IS-IS commands
keepalive Enable keepalive
lan-name LAN Name command
load-interval Specify interval for load calculation for an interface
locaddr-priority Assign a priority group
logging Configure logging for interface
loopback Configure internal loopback on an interface
mac-address Manually set interface MAC address
max-reserved-bandwidth Maximum Reservable Bandwidth on an Interface
mls mls sub/interface commands
mpoa MPOA interface configuration commands
mtu Set the interface Maximum Transmission Unit (MTU)
negotiation Select autonegotiation mode
netbios Use a defined NETBIOS access list or enable name-caching
no Negate a command or set its defaults
ntp Configure NTP
pppoe pppoe interface subcommands
redirect Redirect rules
sap-priority Assign a priority group
service-policy Configure QoS Service Policy
shutdown Shutdown the selected interface
sna SNA pu configuration
snapshot Configure snapshot support on the interface
snmp Modify SNMP interface parameters
standby HSRP interface configuration commands
135
