Community Member
7606: Module for SPA-2X1GE-V2 Card
Greetings-
My company purchased a SPA-2X1GE-V2 card to be used on our 7606 router.  The 7606 has a '2 port adapter Enhanced FlexWAN' module (WS-X6582-2PA).  I tried installing the card into the module and it doesn't seem to fit.  I take it that these two are not compatible.  I tried looking through the 2SPA-2X1GE-V2 data sheet and can't find what this card works with, besides the fact that it's compatible with a 7606.  Can someone assist me with figuring-out which module will work with the 2SPA-2x1GE-V2?
Thanks in advance!
1 ACCEPTED SOLUTION
I believe your module makes use of the port adapters from the old 7204/7206(VXR) routers.  What you need seems to be a SIP-400:
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76intsw.html
Community Member
Thanks for the reply and locating the link to the SIP-400 info page ... makes sense.
166
