10-08-2010 07:09 AM - edited 03-06-2019 01:24 PM
Hi, I have this question:
Our customer performed an upgrade of IOS on Cisco 7613, after the automatic reboot, they received this messages by console:
belong to this routing instance.% Interface Serial4/2/7:1 does not belong to this routing instance.% Interface Serial4/3/0:1 does not belong to this routing instance.% Interface Serial4/3/1:1 does not belong to this routing instance.% Interface Serial4/3/2:1 does not belong to this routing instance.% Interface Serial4/3/4:1 does not belong to this routing instance.% Interface Serial4/3/5:1 does not belong to this routing instance.% Interface Serial4/3/6:1 does not belong to this routing instance.% Interface Serial4/3/7:1 does not belong to this routing instance.% Interface GigabitEthernet5/1 does not belong to this routing instance.% Interface GigabitEthernet5/2 does not belong to this routing instance.% Interface GigabitEthernet5/3 does not belong to this routing instance.% Interface GigabitEthernet5/4 does not belong to this routing instance.% Interface GigabitEthernet5/5 does not belong to this routing instance.% Interface GigabitEthernet5/5.500 does not belong to this routing instance.% Interface GigabitEthernet5/5.501 does not belong to this routing instance.% Interface GigabitEthernet5/5.505 does not belong to this routing instance.% Interface GigabitEthernet5/6 does not belong to this routing instance.% Interface GigabitEthernet5/7 does not belong to this routing instance.% Interface GigabitEthernet5/8 does not belong to this routing ..........
The equipment is working normally in this moment and we don`t see service disruption.
Thanks.
Solved! Go to Solution.
10-08-2010 07:40 AM
Ah ... interesting ... so it was a downgrade that caused the cli differences. That makes sence as well.
I would not worry about it. Once you save the config here, you should not see the same messages on next reboot.
If you want to really find the reason, and you still have your running config from when you had SRE loaded, you could send the two configuration files (SRE vs SRD(now)) to us in a real TAC case (to avoid opening up your info to the world in this forum).
Rob
10-08-2010 07:25 AM
I have seen this before, specifically when someone upgraded to one of our later versions ... looks like you just upgraded to SRD5 ...
What were you running before?
The logs do not indicate a specific problem, but as we changed some of the cli for the bgp address families and such, this may be one of those things we we spit out messages for deprecated configuration combinations.
Rob
10-08-2010 07:32 AM
Thanks Rob for your comments, before the upgrade we had running SRE1.
10-08-2010 07:40 AM
Rob
10-08-2010 07:54 AM
OK Thanks again Rob, I opened a case in the TAC.
