Webcast-Catalyst9k
8 Mbps ethernet drop on cisco 2811 router
does Cisco 2811 router supports 8 mbps ethernet drop if not then which is the starting series router????
Re: 8 Mbps ethernet drop on cisco 2811 router
For details pls visit: http://cisco.com/en/US/products/ps5854/index.html
Goutam
Yes it does. Check the link for more info http://cisco.com/en/US/products/ps5854/prod_models_home.html. Tell me if it helped.
yes it would ...just make sure you shape the traffic to the egress rate
I have a 45Mb Ethernet circuit connected to the 2811 and it works fine
Narayan
287
