802.1q-inq Stacked VLAN's
What switches support 802.1q-in-q Tagging, and is there a limit on the amount of Simultaneous VLANS Supported in each switch? I know some switches have a limit on the number of simultaneous regular VLANS that are supported...Does the same apply to Stacked VLANS?
1 REPLY
Silver
Re: 802.1q-inq Stacked VLAN's
Hi Matthew ,
The below link gives all details of 802.1q-in-q tagging and supported IOS.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_7/gt_qinq.htm
It may help you.
Satish
722
