08-28-2008 10:01 AM - edited 03-06-2019 01:03 AM
I would liek to know if there is a configuration sample to set up a trunk between a Checkpoint-Nokia FW and a Cisco 3750 switch. I know both boxes can do 802.1q. Please let me know.
Thanks.
08-29-2008 01:06 AM
I have a Checkpoint Cluster on IBM Hardware with Secure Linux connected to my 3560E but not Trunked.
Both Firewalls are connected to the same Switch (Single point of failure).
My interfaces are configed like this:
interface GigabitEthernet0/11
description FW1 eth1 ISP
switchport access vlan 86
switchport mode access
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
auto qos voip trust
spanning-tree portfast trunk
spanning-tree bpduguard enable
interface GigabitEthernet0/12
description FW2 eth1 ISP
queue-set 2
mls qos trust cos
auto qos voip trust
Qos is not necessary.
Failover from one Firewall to the otther ist with no interuption.
Willem
08-29-2008 04:02 AM
Hello Willen,
Thanks for the information. But in my case I have the Firewall doing routing between VLANS, so I need to trunk the Firewal(Checkpoint/Nokia) box to the Cat3750.
I am going to use the normal trunk configuration for the switch side and have the FW selecting the interface I am peering to as trunk with 802.1q trunking protocol running on it.
Gilson
