802.1x and List of Methods
progel
Hello, I am Patricio. I have a couples of questions about 802.1x and its configurations on the c3560. 1.- If 801.1x only works with Radious, it makes sense to define a list of methods different from the default? And, How I can to associate a list of methods, different than the default, to the interfaces? Thank in advance.
Giuseppe Larosa
Hello Patricio,
according to configuration guide the list of methods needs to use the default name:
aaa authentication dot1x {default} method1
because default is in curls and because group radious is the only supported method.
Though other keywords are visible in the command-line help string, only the group radius keywords are supported.
the result of this is that you cannot configure two different methods lists for 802.1X authentication.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/sw8021x.html#wp1025133
Hope to help
Giuseppe
Thank a lot, I am reading the document.
