802.1X on a C2950G-12-EI when RADIUS is on a different subnet
I have a C2950G-12-EI which supports dot1x port based authentication. But the Radius server is in another subnet and the switch doesn't support routing.
How do communicate with the Radius server if I can't ping past the local subnet and the Radius server is on another subnet?
1 ACCEPTED SOLUTION
Re: 802.1X on a C2950G-12-EI when RADIUS is on a different subne
You can add the default gateway on the switch using the following:
Conf t
ip default-gateway
If you have you routing set up properly it should. Please attach the config of both the routers and the switch. Let us know the ip address range also.
A brief topology diagram would help in this case.
HTH,
-amit singh
The fact that the 2950 is not L3 does not matter. the problem is that you do not have Ip conectivity to the radius server.
Could you send a netowrk diagram or give some mor infomration about waht your network looks like.
This is what I thought. I must be missing something simple here, how do I specify the local subnet's default gateway on the Switch?
RADIUS SRVR <-> RTR1 <-> RTR2 <-> Switch
Conf t
ip default-gateway
HTH,
-amit singh
Thanks Amit, that was it, thought I tried that and got an error. Must have been one of those days.
185
