802.1x wired deployment on xp & win2k clients
We have already got this working, but need to find a way to push the network card settings out to all of the client machines. By network card settings, I mean that we need to tell the network card to use 802.1x authentication and we need to tell it which certificate to use. We need to be able to do this remotely via using some sort of script or GPO as there are too many machines to go around and do this manually. Does anybody have any ideas?
Hall of Fame Super Blue
Re: 802.1x wired deployment on xp & win2k clients
Mark
You don't say which server version you are using but if it is 2008 you can use GPO, see this link -
2008 GP 802.1x
it should be said that this is really a Microsoft question rather than Cisco, so if you are not using 2008 it may be a good idea to search technet for your particular server version. GPO for wired 802.1x was not supported for quite a while by Microsoft because they recommended using IPSEC for wired clients and only 802.1x for wireless.
Jon
They are 2003 DC's, but we could get 2008.
Mark
Might be worth having a quick search of Technet/Google for 2003 GPO 802.1x wired.
Jon
ah, looks like the group policy options in 2008 only work with XP and above. Anybody know any way of doing it on win2k machines?
Mark
Not trying to put you off but you might be better either -
1) moving this thread or reposting to the wireless forums where there may well be people who can answer your question
or
2) posting question on Microsoft forums
This forum is specifically to do with LAN switches and routers which is not really related to what you are doing.
Jon
Anybody have any other ideas?
Hi Mark
As per me i dont think that there is any script that can unable Dot1.x in network card setting.
But you can push the certificate through GPO in Win 2003 Server. When user will login then it will promt that whether you wnat to use this certificate or not , But you can't force directly that the certificate should enable .
https://support.smoothwall.net/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=180
Please refer the below link.
Chetan Kumar
418
