802.1x with MAC Authentication Bypass, Guest Vlan and Auth-Fail Vlan
jspichalla
I want test a scenario with different vlans. On my Switch Port is this following configured:
interface GigabitEthernet0/4
switchport mode access
switchport port-security
switchport port-security maximum 5
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
switchport port-security mac-address sticky
speed auto 100
dot1x mac-auth-bypass
dot1x critical recovery action reinitialize
dot1x pae authenticator
dot1x port-control auto
dot1x host-mode multi-host
dot1x control-direction in
dot1x timeout quiet-period 2
dot1x timeout server-timeout 2
dot1x timeout reauth-period server
dot1x timeout tx-period 1
dot1x timeout supp-timeout 2
dot1x max-reauth-req 1
dot1x reauthentication
dot1x guest-vlan 7
dot1x auth-fail vlan 7
dot1x critical vlan 6
spanning-tree portfast
spanning-tree bpduguard enable
My question is, can I combined this features on a port? By corrupted MAC-Address should be the PC in guest-vlan, by corrupted certificate should be the PC in Auth-Fail vlan.
Is that correct?
thanks for your response
Jens
Amit Singh
Jens,
I am in doubt that this thing will work. As dot1x is not doing the MAC authentication in this case and Port-security will come into the picture first.If it is the sixth/corrupted mac-address port-security will not allow the traffic to passs at all and all the packets from the source MAC will all the dropped.This will not allow the dot1x to do the vlan mapping.
The other feature will definately work i.e the corrupted certificate PC will fall in the Auth-fail Vlan.
HTH,
-amit singh
