802.1x
Hi all, how would I configure my switches with this?
Re: 802.1x
Hi Carl,
have a look at "Access Control Design Guide"
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns251/c649/ccmigration_09186a00806805d6.pdf
Or have a look at the configuration guide for your particular switch and IOS version. There is a section describing 802.1x
Hope this helps!
Regards, Martin
Re: 802.1x
Carl,
Check this link out and with the help of this link you will be able to configure 802.1x on your switches.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225se/3560scg/sw8021x.htm
HTH,
-amit singh
120
