851 Router SDM Wizard not working
mackeyuk
I have just powered up a brand new 851 router and proceeded to configure it using the SDM Wizard as explained in the enclosed guide.
However I get as far as the DHCP options page and then click 'next' and nothing happens. I have tried using both IE and Firefox but with the same results.
HELP!
Lucien Avramov
Level 10
Level 10
This is most likely due to not using the supported java runtime environment JRE version.
SDM does not support java after: 6u3.
Cisco SDM requires Sun Java Runtime Environment (JRE). The following versions are supported:
•JRE 1.5_09
•JRE1.4.2_08
•JRE 1.5.0_06
•JRE 1.5.0_07
•JRE 1.6.0_02
•JRE 1.6.0_03
As per the release notes.
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/software/release/notes/SDMr25.html
Also configuration guide may be handy:
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/25/software/user/guide/SDM25UGD.html
