857w Unable to obtain DHCP address over WLAN
I have configured my 857w via combination of the SDM and CLI.
As it stands I have two issues:
1.Unable to obtain DHCP address over WLAN
2. MSN messenger is unable to connect.
Attached is my config.
I would be grateful if someone could point me in the right direction.
Re: 857w Unable to obtain DHCP address over WLAN
Paste the following config:
show run
show vlan
show interface f0/x switchport
show interface f0/x trunk
show spanning-tree interface f0/x
'Where f0/x is the interface that the Airespace controller is attached'.
Silver
Hi David
I spent last weekend working on configurng both a Cisco 837 and 877 ADSL rotuer to access my ISP. This was the first time I have ever tried this and I also posted on the forum looking for help.
I received some extremely helpful replies from a forum member "Edison Ortiz" with links to documents which help with this configuration and with troubleshooting problems.
The post appears to have vanished (at least I can't find it. However here are the links provided by Edison
For configuration: http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a729.shtml
For Troubleshooting: http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a7c2.shtml
Now I am no expert at this as I said above but looking at your configuration, something that I did notice was that there are no global Point to Point over ethernet (pppoe) parameters configured (see section 4 on the configuration link).
In the configs that worked fro me over the weekend, I had the following lines of configuration.
On the 837 which received an IP address from the ISP dynamically:
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
On the 877 which has a static IP address assigned by ISP:
vpdn enable
vpdn-group 1
Your configuration looks pretty complex (to me anyway) and there are parts of this I don't quite understand. However if it was at all possible, it maybe worth while (if the addition of the pppoe parameters don't work) to start with a simpler configuration and then when you have all the basics working, adding the rest of the configuration back in.
This post http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbf9965 shows the configuration that worked on my 837 router with dynamic IP address assignment from ISP.
Maybe this will help a little.
Best Regards,
Michael.
Silver
Hi David
You can probably ignore most of what is above.
I read the title of your original post as "Unable to obtain IP address over WAN" when you actually wrote "WLAN"
Best Regards,
Michael
115
