08-15-2008 10:34 AM - edited 03-06-2019 12:49 AM
I'm having a heck of a time configuring an 861-W ISR. All I'm trying to do is configure it for basic internet access for 1 hardwired PC and 1 Wirless desktop. Does anyone have a sample configuration or point me to one for this type of setup? Below is my config
sh run
Building configuration...
Current configuration : 1772 bytes
version 12.4
no service pad
hostname ISC_TORRANCE
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret xxx
enable password ICAI
no aaa new-model
no ip routing
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.41.1
ip dhcp pool DHCPpool_0
network 192.168.41.0 255.255.255.224
dns-server 10.0.2.100
default-router 192.168.41.1
no ip cef
ip name-server 10.0.2.100
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
hidekeys
interface Loopback0
no ip address
no ip route-cache
interface FastEthernet0
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
ip address 10.0.2.204 255.255.255.0
ip nat outside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
no ip route-cache
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
ip address 192.168.41.1 255.255.255.224
ip nat inside
no ip route-cache
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool data 10.0.2.204 10.0.2.204 netmask 255.255.255.0
ip nat inside source list 1 pool data overload
access-list 1 permit 192.168.41.0 0.0.0.224
snmp-server community public RO
control-plane
line con 0
no modem enable
line aux 0
line 2
line vty 0 4
password xxx
login
scheduler max-task-time 5000
end
11-04-2008 03:23 PM
The NAT Pool address overlapping with the interface's IP might be part of the problem. Try this:
no ip nat pool data 10.0.2.204 10.0.2.204 netmask 255.255.255.0
no ip nat inside source list 1 pool data overload
ip nat inside source list 1 interface FastEthernet4 overload
Also put your Ethernet port in portfast:
spanning-tree portfast
11-04-2008 03:23 PM
Oh, and fix the mask on Access-list 1:
no access-list 1 permit 192.168.41.0 0.0.0.224
access-list 1 permit 192.168.41.0 0.0.0.31
