Community Member
881w router to distribute DHCP to switch
I have a 881w router with static wan ip ssetup on fastethernet 4 and vlan1 distributes ip from fastethernet 0. It works fine when I plug a PC directly to fastethernet 0, address is assigned and internet access is connected, the problem is when I connect the fastethernet 0 to a switch no ips are distibuted and even static routing a PC connected to the switch gets no connection. Can someone please help me what I am missing?
Here is a piece of my running config:
ip dhcp excluded-address 192.168.1.1
ip dhcp pool local
 import all
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 66.180.96.12
ip name-server 64.238.96.12
ip name-server 66.180.96.12
no ipv6 cef
interface FastEthernet0
 switchport mode trunk
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address xxx.xxx.248.98 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 no ip address
interface wlan-ap0
 description Embedded Service module interface to manage the embedded AP
 no ip address
 shutdown
interface Vlan1
 ip address pool local
 ip nat inside
ip forward-protocol nd
ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 23 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 xxx.xxx.248.97
access-list 23 permit 192.168.1.0 0.0.0.255
Community Member
Hi, you should give an ip
you should give an ip address to fe0, then define int vlan 1 on your switch, and make sure that the port which you're connecting pc is in vlan 1.
Houtan
Community Member
thanks for the reply, it will
thanks for the reply, it will not allow me to give fe0 and ip says "IP addresses may not be configured on L2 links."
the switch is currently setup as vlan1.
specific commands I may be missing would be greatly appreciated.
Community Member
Try "no switcport" on fe0,
Try "no switcport" on fe0, then apply ip address.
on 881
 no switchport
on switch
interface vlan 1
no shutdown
57
